when I put my boat into forward position it does not kick into gear till i bring the revs up to 1300 or above.What could be causing this.Low oil in my outdrive, streched cable?
Thanks Colm
DO NOT start randomly shimming the shift bolt.
if you do it wrong you tear up about 1000 dollars worth of parts almost instantly.
DO check the cable adjustment per the service manual.
if the drive end needs more thread then adjust the trunion at the control box end.
with some aftermarket rigs I have actually had to use a 10-32 die and add some thread to the drive en of the cable.
those shims behind that 9\16ths bolt on the shifter are for going to N and have nothing to do with into or out of gear.
also if the drive has been overfilled with oil you get the same symptoms.
repeated sudden engagement at 1300 RPM can and will lead to a hole in the top cover and a lost upper drive shaft.
seen it a few times.
