I have a 92 Johnson 40 hp I bought it not running but the compression checked out at 121 on both cylinders cold.I drained the bad gas, installed new plugs and it fired up immediately but wouldn't idle.I installed a new waterpump,changes the foot oil ,removed the carbs disassembled and cleaned them WELL fired it back up and it ran better but still wouldn't idle and ran rough .It would run if I bumped the key primer or gave it more fuel with the throttle bu then it would turn off with the key.I replaced the switch but really didn't think it was the problem as it wasn't checked the kill switch with a test light and ohmmeter . It was good.I tried testing th black and yellow wire with an ohmmeter from the switch to the engine and didnt get a connection at the harness where it plugs into the "power pack" .I had it unplugged. I did have a connection at the red harness connector . My problem is the killing of the engine with the key and idling and rough running. Please help?
