help i have a 1966 40 johnson wont idle just backfires and dies..if you idle it up it will run rough
i have replaced plugs .030 wires, points .020 condensers coils cleaned and adjusted carb adjusted link to timer base replaced carb and flywheel from another running motor spark is good and jumps 7/16 compression is 118 on both any suggestions?
