Re: won't idle
When you rebuilt the carb, did you remove the soft metal plug above the idle orifaces and make sure everything was clean in there? How does it run at full throttle? Does choking it a bit help?<br /><br />Could also be a crankcase leak via the top or bottom crank seals; when you have the flywheel off to clean up the points, check to see if there's any evidence of oil leaking though it. An airleak may also show up as a difference on the insulators of the spark plugs, but flaky points will also do that.<br /><br />Good luck, and tell us what you find!
