I have a 92 evenrude 40hp. I have only owned this boat since June of this year and it's been out of the water more than not. The problem started with the boat not running at top end. It would run fine at slow speed but when you rev'ed the engine it would drop back to about 50%. I've had carbs cleaned and adjusted and finally had the engine looked at by a pro. He cleaned carbs and rebuilt, re-adjusted everything and replace the fuel lines inside the engine hood. The fuel lines had what looked like tar inside of them and whatever it was was breaking down the rubber and making it Mushy. After his overhall it ran fine at first and was finally a joy but we used the motor to troll and now it misses at much over half throttle and acts like it's starving for fuel. The first time we ran it till we blew it out and again it ran fine at top end. After trolling for about 15 minutes the engine would not run smooth at high rev's and acts like it's starving for fuel, well it lunges instead of running smooth. I bought the pontoon boat to troll with and now I'm being told it's always been a problem to troll with this size motor. What do I do? Fuel additive, 3rd mechanic, new motor???? HELP!!!!!!!!
