Re: wont shift into reverse
redman, hum, well, think i'd approach it this way. disconnect the shift cable. you should be able to manualy shift into F or R by manipulateing the shift cable going to the outdrive. have a helper rotate the prop counter clockwise and see if it the prop locks, as in F. pull the cable the other way and rotate the prop clockwise and see if the prop locks up, Reverse. asumeing that's ok, i'd try to operate the remote and see if the cable moves free. seems like there's a spec on length of cable, ya might want to look that one up. aslo, my 165 has a bunch of levers that operate when the shift cable is moved. reckon they's the throttle and lost motion for a single lever remote. i thinki i's see if those nylock nuts have got to tight and restricting movement. my 2 cents worth(guesss), ya gotta start somewhere,,,,, this info is related to my 72 I drive, ya might have a much newer drive than me. jim
