Won't start all of a sudden.. Load too much...
kimchee
I have a 5.8L mercruiser V8 I/O engine in a 1996 maxum 2300SC (that is to say it is a 23 footer)... I have been riding my boat fine, however after not riding the boat for about 2 weeks I decided to goto the marina just to keep the batteries nice and charged.. When I got there, I tried to start the boat, but I could not not turn it over, When I turned the key, it just clicked once, as if the starter had too big a load to crank over... When I tried again, I heard a loud slam, and then the engine froze again, as if it locked... I was getting nervous, so I figured what the hell, let me try again... When I did, it happened again, a loud slam, then it locked again... It seemed obvious at this point, that whatever I was doing, was causing damage to the engine. So I stopped.... At this cross road, it seems I have a couple of options...<br /><br />-Pull the boat out of the water, and worry about it next summer, (I live in New York City)<br />-Call a mechanic, and be at his mercy...<br />-BEG YOU GUYS TO HELP ME OUT !!! and see if there is anything I can do...<br /><br />You all really helped me through changing the starter, oil, plugs, cap and rotor.. Please help me through this...<br /><br />Am I screwed... Has my engine been blown... How can I relieve the load off the starter.<br /><br />Thanks Everyone... :(
tommays
Re: Won't start all of a sudden.. Load too much...
i would pull the sparkplugs ASAP look for signs of water and see if the motor cranks and pushes out water<br /><br />if there is water the next step is HOW did it get in there <br /><br />a one time thing like shutting down to fast OR a part failure ?<br /><br /><br />tommays
Bt Doctur
pull the spark plugs to check for water in the cylinders,if no water found pull the drive and try to spin the motor. if yes, install plugs and try a restart.need to isolate between the motor or drive.
jaybirdtx
If it was sitting in the water at the marina you probably got water in the exhaust, causing a hydro lock. NOT GOOD. Get it to a shop ASAP.
