Angiecobra
- Jul 20, 2016
- 2
I got a 1987 OMC Cobra 4.3. with similar problem. Got new battery, new starter/selenoid, new assist selenoid, new fuel pump and filter. Actually I have two problems, first, boat will not start with key on start position. Tested ignition switch and is ok. Gauges work on run. Blower did not work, change a fuse and is working now. Tested cables for continuity test ok. Dont know what esle to do.
Well, second issue, if I hot wire at the selenoid, motor cranks and starts, but as soon as I let go it dies. Any help?
