won't start
rdtoli
1973 115 johnson outboard problems!! Have replace the ignition switch, starter, coils. Started it and would not cut off with ignition switch. So took ignition switch apart and tried to stopp it that way and something popped. Then it would not do anything turn switch and it dont even click. Replaced the solenoid and it stills does nothing Please help what can it be. Thank you rdtoli<br />ok sry forgot a few things <br />model 115ESL73M<br />serial 13888075<br />thanks again
D
DJ
Guest
Re: won't start
Look for a fuse at or near the starter. It is in a connector that looks like a regular wiring connector. It is very small.
rdtoli
Re: won't start
Thanks guys but still nothing made a new post. Won't crank with a little more detail. Trying to get use to how to do these things. So if i mess up sorry just let me know. Thanks again.
