I have a 88 Procraft with an Evinrude 1987 E150TLCU and it won't run unless you have the choke lever pulled up. I found a burnt whole in the rectifier/regulator. What could of caused this and would this cause it to not get correct for to run at idle? I was able to push the chole lever down real quick and get it in gear but it would only run around 38mph. Next question is getting the flywheel off. It looks like there are 3 threaded holes to help press the flywheel off, is that correct and if so what size and thread are the holes? Thanks for all the help.
