Wood filler?
GatorMike
Ensign
I have to do a little patch work on my boat, really a small job but because of where it is I was wondering if anybody had any suggestions on a product to use.
A few years back I put rod holders in that are recessed into the gunwales of my boat. When I drilled the screw holes for the starboard rod holder I ended up drilling two of my holes right on the edge of the large hole that the holder recesses into. Needless to say those two screws did not hold for long and that holder has been secured with one screw for several years. That screw has finally worked itself loose so I am going to fill that hole and the other 2 with some kind of filler and redrill the holes.
My problem is going to be finding a product to fill in the two holes that are now part of the one big hole in the middle. Hope I explained that well enough. Anybody have any ideas?
oops!
Re: Wood filler?
peanut butter or marine tex.....if you use the pb....just glass it form the back side
