wood floor
beertech44
Im redoing the floor on my aluminum boat. Is half inch plywood stained with outdoor wood sealer good enough.
tengals123
Master Chief Petty Officer
Re: wood floor
IMO,<br /><br />No, it's not good enough. seal it properly with poly resin. Otherwise you'll be replacing it in a years time. cheers
tengals123
Re: wood floor
not at all. You can buy it hardware stores, homewares etc...
Realgun
Re: wood floor
I would suggest that you use as dry a treated plywood as you can find. Then use a good outdoor paint to seal it up. Minumum 2 coats and get the edges too.<br /><br />You could use just exterior plywood and use 2 coat of 2 part epoxy as poly is not as good sealer.
tengals123
Re: wood floor
if you can afford epoxy, yes it's better. Im not a fan of using outdoor paints in high traffic areas, such as a floor, but up to you i guess. cheers
flashback
Re: wood floor
beertech, you didn't give us too much info on the boat other than it is aluminum.. if I had a small fishing skiff I would just built the floor out of decking material like 5/4 by 6" PT and be done with it for 10 or 15 years.........any water will run right past it and into the bilge....... :D :D
beertech44
Re: wood floor
Sorry I have a 17 foot aluminum lowe boat. It has a front and back casting deck. I was hoping there was a plywood I can get at home depot or a big chain as im in canada and my options are limited. Is there a plywood and sealer I could get at home dept. I did notice they sold marine carpet there. My boat is stored indoors and the floor is rarely wet
tengals123
Re: wood floor
get some exterior ply, 2 part epoxy resin and coat the edges, top and bottom and install.
beertech44
Re: wood floor
can I find this epoxy resin at home depot how big of quantities does it come in. should I buy presure treated plywoon
Re: wood floor
I'm not saying that Any of the info above is Wrong,...Because it's Not........<br />But,.. For what you're trying to accomplish, I see an Awful lot of Overkill............<br /><br />I think that Your Plan A will do Just Fine......<br />Starting with P/T Plywood IS a Big Plus.......<br />P/T/ plywood, By itself will Outlast You,+ Your Boat........... :D
gewf631
Re: wood floor
I agree with Bondo.<br /><br />I've got a '76 Starcraft and the original 1/2" plywood wasn't P/T, just painted. No rot - but someone dropped a scuba tank and put a hole in the floor! <br /><br />I upped to 3/4" P/T - I'm sure it'll last just fine.
Wizard1
Re: wood floor
I've got a question, how well does the epoxy hold up on plywood? I mean , if your plywood floor flexes , over time would the epoxy crack underneath allowing moisture to penetrate the wood? If you can't tell I've never used epoxy before. :cool:
Wizard1
Re: wood floor
Thanks Tengals123, as I said I've never worked with epoxy so this helps me make what I think will be the right choice.
