Wood replacement, stern of a 1985 SportCraft OSFF 222
MCJEB
Need photos of the original wood covering the opening on both sides and behind the engine cover. The only piece left is what the battery switch is mounted on. Looks like 3/4" plywood. The engine is a 4 cylinder 170 Volvo.
kcassells
Good luck. Not much info in that dept. What are the other problems you are trying to resolve>
AShipShow
Yea, you MOST LIKELY aren't going to get the info you're looking for unless you can find someone with the same exact boat that is willing to help.
More than likely, you will need to make your own templates and cut out your own new pieces.
kcassells
Google "sportscraft 222 pics" you may see something you can use. Also even if it's a larger boat back from the day
you may still be able to get a visual to pull off your repair.
Best of luck. Keep posting. :**
I'm rehabbing my sportscraft 222 but its an outboard. Like MP said. You'll figa it out.
