wood seat sealer
mrnaasty
hi all i have a 1958 crestliner super seaman with the redwood bench seats what is the best way to prep and seal the seats for heavy use
eaglejim
Re: wood seat sealer
check into the spar varnish line of product.
marine4003
nasty, it all depends on how much maintainance you want to have, you can sand them down and apply 3-6 coats of quality varnish,then every spring & fall sand off a coat and apply more to keep it fresh,or you can sand it down and apply a good wood preservative ( Cabots).the choice is made based on work & looks.
mrnaasty
hi,thanks for the responses would minwax spar helmsman do the job or ......................?
Coors
Consumer stores sell products labeled spar, but...
don't think Miniwax is marine spar, that you want. Call a paint store.
marine4003
Nasty, Minwax "spar" is called spar due to its ability to "flex" some...back in the old days regular ol' varnish was very brittle when dry,and had a tendency to flake off,especially off of the mast or "spar" so additives where introduced to allow flexing without flaking...BUT marine grade varnish has alot of UV inhibitors allowing it to outlast regular varnish...so, as mentioned above,go with a Marine Grade varnish, after using everything out there,i highly recommend Epifanes. Or even Awlgrip makes a clear coat,but its dam expensive.
Application : cut the first coat 50% w/ thinner,this will allow greater penetration of the varnish, Cut 2nd coat 25%,then apply full strength,results will last far longer..Good Luck.
