Wood working / refinishing
redneck joe
Have an old chest that a yougun decided to carve on. I sanded down the finish and the scratches but those areas are now much lighter. Will the new finish match the wood up? I don't want to put a coat on then have to sand it back off and if i sand off all the old finish and it doesn't darken back up it won't match the sides and front.
fhhuber
Wipe it with a damp rag. That will simulate a clear coat. You'll have to do another final sanding because this will raise the grain, but you will see what you have.
redneck joe
ok did that the light color is dang near a perfect match but the dark is still coming up lighter. And thoughts?
Also, doing that I see two scratches I didn't get all the way out so regardless thanks for the tip.
