Woodnaut
- Jul 4, 2007
- 634
I'm installing a fixed-mount VHF radio and don't want it too close to the compass, but it needs to be close enough to reach while underway. The best place for it is right in the center of the dash but this could be a problem. The windshield opens in the middle for entering and exiting the boat, so the center of the dash gets bumped around quite a bit. Also, the anchor is usually tied off on the forward deck and the excess line is wrapped around the handy cleat that's in the center of the dash.
Nevertheless, the center of the dash is the best place for it, so I've decided to fully recess the radio and cover it with a piece of 1/4" Lexan for protection. To do this, I need to increase the thickness of the dash in this area to about 3", and then use a router to cut a rectangular hole to mount the radio. I'm using a piece of plywood with a rectangular hole as perfect guide for the router. By moving the router around inside of this guide, a hole of the exact size needed will be cut.
To give the dash the total thickness required, a couple of mahogany blocks have been cut to size and mounted in the correct location behind the dash.
This picture shows the first pass that was made with the router. I'm using a 1/2" straight plunge bit.
After a few more passes of the router, the full 3" thickness of the dash has been cut through.
The plywood template was removed, its guide hole was enlarged, and then it was carefully repositioned on the dash. A few more passes of the router was made to counter-bore a larger hole. This time the cut did not go all the way through. A ledge was formed in the bottom of the hole that the radio will mount against.
