Workshop & Parts Manuals
Taz59
Looks like I will have to rebuild my Outdrive so looking for the best Workshop & Parts Manuals for a
2007 DPS-A 1.95
3883609
Any help appreciated
Taza
I downloaded the manuals direct from volvo penta
Taz59
Guys what special tool will I need when stripping both upper and lower drives, the drive has been removed from the boat.
BRICH1260
Assuming you mean paint, Are you wanting to totally strip the unit or just certain areas? If the entire unit, use an aircraft type of aluminum stripper. If just areas, use just about anything but a steel wire brush or pad. I use 3M sanding pads, green and brown along with a flapper sandpaper drill disc.
Taz59
No as was referring to what special tools will I need to replace seals & bearing in the drive
Thanks
manual will cover most of what you need
outdrive stand (there are a few writeups on making one)
small torque wrenches
in-line scale for setting bearing pre-load
digital calipers for adjusting shims
