I am wondering how to go about fixing the drive shaft on my 1965 9.5hp. As the picture shows there is a groove worn into the shaft were the seal rides below the impeller plate. How much of a groove is to much. I measure .0015" of difference while rotating the shaft on the surface plate at work. I'm not sure if this is enough to worry about when I put a new seal in or not. Has anyone else had this problem with a drive shaft leaking or not? Thanks
