WOT CONFUSION
HYDRASPORT84
I have a 1998 250 hp Johnson Oeanrunner. I have been told in previous post the wot should be between 5500 and 6000 rpm. Local mech. says 4500 to 5500 rpm who is right?????????
P.V.
Re: WOT CONFUSION
Local Mech is having "flashbacks" to the old cross-flow days/daze!! Look at you owner's manual or the nice factory service manual you bought!!! Loopers "generally" run 5 to 6K. I don't have the exact # memorized and neither does anyone else here!! So I won't make up a number that isn't correct!!!!!!
HYDRASPORT84
Re: WOT CONFUSION
I have a 14-3/4 x 19 prop. I need to go down to a 17 pitch to raise rpms. Do i stick with the same diameter??
Hooty
Re: WOT CONFUSION
I've got an old V6 Xflow that runs all day long at 6 grand. It just hummmmmms. :D <br /><br />c/6<br />Hooty
HYDRASPORT84
Re: WOT CONFUSION
I have a 14-3/4 x 19 prop. I need to go down to a 17 pitch to raise rpms. Do i stick with the same diameter?? <br />--------------------------------------------------------------------------------
roscoe
Re: WOT CONFUSION
Yes, or something close to it. Sometimes the same diameter isn't available.<br /><br />19p to 17p should give you 300-400 more rpm
