I have a 17.5 sea nymph aluminum runabout with a 1978 Johnson 85hp manual tilt. I am running a 17p stainless prop it has had carbs rebuilt ,new tanks, new lines new coils, new powerpacks,new fuel pump . compression is 120 on all cylinders.It cruises at 3400 24 mph and top speed is 33 at 4200. with 2 people and 2 batteries 2 full 6 gallon tanks.Does anyone have a similar setup does this sound normal and tach not right or do you think I have another problem. I tilted engine either way and the tilt pin hole is third from bottom and boat runs the best.It runs good and starts good. I worry the rpms are too low. One other thing the idle screw is almost maxed out I don't know if that makes a difference.
