halmc
- Feb 27, 2008
- 231
I have an '88 Mercury Classic Fifty on a pontoon boat; because of intermittant issues with cylinders #1 and #2, I've ordered a new switchbox and expect it any day. Perhaps the switch box will cure this issue, but I'd sure like to have a bit of advice anyway:
This engine typically runs initially, only on #3 and #4, and at WOT, the tach reads about 2900. Fair enough for two cylinders. After a bit of running, #2 often comes on line. With three making power, Tach reads about 3600. Usually -- and inexplicably -- after extended idling, #1 fires up, and the tach rises to about 4300. With all four cylinders on line, I get an indicated 4300rpm, boat speed is about 17kts, about what I'd expect for a moderately loaded 20' pontoon boat. Sounds initially like an over proped boat, but to my ear the engine is turning faster than 4300, but that's what the tach says.
While I'm making the 4300 and 17kts, I have hung off the back of the boat and shorted each plug at the top of the plug, so I do know that each cylinder is making power.
Here's the kicker: a few weeks ago, before I started investigating this engine's erratic performance on the top two cylinders, at WOT, I got an indicated 5800 rpm on the tach. Unfortunately, I didn't have a GPS to meausre boat speed, but it 'feels' like the boat is as fast now at 4300 as it was then with an indicated 5800.
Perhaps the switchbox is boogered enough to either 1) cause the tach to indicate a lower rpm than the engine is actually turning? or 2) perhaps the switchbox is boogered enough to be causing one or more cylinders to be running with coniderably less than their rated power? (the latter seems distinctly unlikely)
Ideas, or opinions?
Ideas, or opinions?
