Re: WOT rpm?
Original RPM range spec for a 1976 Johnson 70 HP is 4500 to 5500 RPM. You definitely want to prop towards 5500. Some say to run a little faster, some say not. One thing is for certain: If you are getting 32 MPH out of you current 17 inch prop, you are running more than 4000 RPM, so your tach is questionable. With your motor's gear ratio, 32MPH on a 17 pitch prop at 4000 RPM is mathmatically impossible. Also, I have the identical motor ('76 Evinrude 70HP) and with my 16' boat running an OEM aluminum 17 pitch prop I run 33 MPH at 5400 RPM. No disrespect to Steelespike, and many boat speedometers read fast, but I don't think 40 MPH with your boat on a 70 HP is realistic. If you can prop for an accurate 5500 RPM and be close to 35 MPH you will be doing well.
