Wot rpm
voodoo
Alot of people seem really concerned that their motor spins at max rpm...<br />Is it better not to rev the snot out of it say run at 4000-5000 rpm on a motor that is rated 5000-6000, or should you always be in the recommended range if you are on plane and cruising?
Dhadley
Re: Wot rpm
You can run it all day long at whatever rpm you choose as long as its capable of the right rpm.
