500dollar744ti
- Jul 23, 2012
- 691
I have a 1990 MCM 350 Magnum, I don't have the S/N handy but let me get your opinion anyway.
Took the boat out for the first time memorial day and didn't have any issue except the temperature was creeping up past the normal 140* and continued past 180* at wide open throttle. WOT is 4400 rpm for me, pulling back to 3900rpm brought the temp right back down to normal.
Last year I replaced the lower unit at the end of the season but did not have a chance to get out on the water. I bought a used lower and put a new (but had been for a couple years) impeller in the water pump. I installed everything, tested it on the muffs in the driveway then winterized the thing.
Before swapping the lower unit everything was perfect, never had temperature creeping up. The water pump housing didn't look too bad to me but I can't think of anything else to cause the issue. Manifolds and risers are new OEM mercruiser.
I just put another new impeller in it and replaced the housing, noticed a small tear in one of the gaskets, hoping that's the issue but it didn't look like the tear was in a spot that would cause a problem.
Anyway, do you all agree in replacing the pump housing and impeller to fix this? I can't think of anything else.
