so i got the motor running kind of ok takes awhile for it to build up speed and get on plane so i took out the plugs
grounder out each wire and check timing while cranking the motor at wot and the reading was 32 degrees wot spec
for my motor is 30 degrees so i set it at 26 while cranking as the method suggests could this have been my entire problem i dont think it would run at all being that far out of time?
