Would a prop too thin..
mnm99
cause more flex resulting in more or less rpm? If a prop was redone too many times and was getting thin on the blade side. Thanks
A prop shop worth its salt measures blade thickness
Texasmark
I had an OEM aluminum prop on a 1972 Johnson 125 back in 1972 that got a trip to the prop shop every Monday after a weekend on the water for its first summer.....before I bought an OMC SST (Stainless Steel Teflon...coated). I didn't notice any reduction in performance over the summer on an 18' boat which pulled a lot of skis.
Sea Rider
Just curious, this blade flexing is something that's been technically corroborated by prop manufacturers on water tests on laboratory, word of mouth, whichever. Assume too much flexing will produce prop vibrations at speed, lose of best blade grip on water along less rpm ? The higher the HP, the thicker blade will be if are aluminum built.
Happy Boating
jimmbo
Blade flex, the term has been very successfully marketed to sell a lot of SS props.
Texasmark
I'm not a propulsion engineer so I don't know the "bending moment" of certain cast aluminums nor the resistance to thrust offered by water to props attempting to turn in water but this is a fact. Turning Point Hustler put a lot of technology in their props. I have one. The thing that they don't have in their alum. props is stainless steel. However, they do have their own special formula/process that produces a rigid aluminum that allows them to make their blades thinner than the norm thus getting as close as they can to SS without the cost. All their amenities in their props are readily available on the www.
So, apparently there is something to aluminum blades bending under high load factors.
Sea Rider
Read somewhere that SS props are only good for + 40-45 MPH speeds, so useless on much less powered OB's that runs say 20-35 MPH.
Happy Boating
jimmbo
So has Mercury and BRP.
I have handled several TP props and have noticed their Quality Control to be lacking. Several props had a change in the rake angle midway up one blade.
People will buy the aftermarket brands because they are cheaper, and because they see/hear advertisements that the prop is better. I myself have never gotten better performance from an aftermarket prop than what I attained from Merc or OMC/BRP props
Texasmark
Well sir you don't have to take a back seat to anybody. Your Avatar says it all. Care to say what your numbers were when that picture was snapped? Light chop, not crossing a wake (don't see any)?
jimmbo
That pic was taken 5 or 6 years ago so I can't recall any specifics(my cousin was driving) other than the prop is a 20in Enertia.
Texasmark
Here the pic a bit bigger and one before it
0.60 seconds later, my avatar shot
(Moderator, we're waiting on originator of post, not stealing his thread) Really nice for a rig that size; I/O at that. What's your mil and mph?
jimmbo
VP 5.7. Speedo quits at 55mph, but needle continues till it is pegged, the engine is not at peak rpm when speedo is pinned. Other boats who have paced me say It goes a bit over 60. With a 4bbl on it, the rpms increased about 10%, so I had to go to a higher pitch prop and it did go faster, as the speedo pinned at a lower rpm but the top rpm was still about 100 higher than with the 2bbl. I would guess it goes about 66 with the 4bbl
Texasmark
I believe it with no more hull than you have in the water and with the deep V it's like you are "on the pad". Glastron is a fine hull. I used to live in Austin where they were originally made back in the '60's.
