Would it work?
Soundslikefun
I'm in the process of painting my 1964 MFG and I was wondering if I could use ratchet straps from the garage truss to the loops on the front and back of boat to lift a few inches off trailer. Boat is 16' and motor is removed. Would my garage support this? I assume it will. It's just a few years old.
MrMarine
Re: Would it work?
If you have some heavy duty straps yes it will work. But by all means if they are Wal-Mart specials then dont even try it. You will regret it.
woosterken
Re: Would it work?
I would get some 2x4 or 4x4s and use them as support legs,just past the width of the boat just to be on the safe side!!
you don't want to pull down the roof of the garage
woosterken
Bob_VT
Re: Would it work?
Two issues......
Make sure you spread the laod across the beams and you are not pulling on one beam in the cieling of the garage........
Considering the year of the boat I would rather see you use a sling under the hull...... I would not have faith in lifting from the 45 year old hooks.
TheWoodCrafter
Re: Would it work?
I did that.
As said if your not sure add 2x4 wedged to the floor.
Soundslikefun
Re: Would it work?
Two issues......
I was planning on spreading the load, but I think your second suggestion is a good idea too, thanks.
