jumpjets
- Nov 11, 2010
- 313
I just "de-winterized" my boat. Mind you, I'm a super novice boater, and pretty much everything I've done to the boat so far has been influenced by reading threads on this board.
It started right up, and idled fine. The gear shift works, as does almost all of the other systems on the boat. I do have one issue I'm worried about though: when I lay down on the deck to inspect the engine with it running, I can hear a disconserting noise from the rear of the engine. It sounds like a faint grinding noise with an occasional rattle.
I'll take a video of it and post it if that not a detailed enough description.
In the mean time, I think I'll grease the heck out of the bearing to see if it goes away.
