wrong impeller? what motor do i really have?
DJ87
hey guys
Im really confused and need your help. I ordered a new impeller kit for my 1987 bayliner capri bowrider with a force 125 engine. when i ordered it from ebay it said the kit fit 1987-89 force 125 "d" models. i couldnt find any other so i ordered it, but its not right. the impeller and gaskets are bigger then what i had in my motor and it seems the impeller is taller then the stock one. the part number on the box says sierra 18-3251d. i looked up the impeller on iboats tonight and it lists a 1989 force 125 L drive only. is my motor not a 1987? is it a 125? it says on the cover it is and the spark plugs are right for a 125. any help would be great.
Nordin
Re: wrong impeller? what motor do i really have?
Modelnumber please and it will be easier to identify.
I think you have ordered a kit to a Mercuy design impellerhouse. In that time 1989-90 Mercury put Mercuryparts on the Force engines.
If you have a LU with single exhaust design, a impellerkit for Chrysler 3-4cyl. engines will fit.
roscoe
A model and serial number would help.
Also a photo if you can.
125 through 1989
120 was made in 1990 and later.
iboats lists your impeller as 18-3030
Force Impellers - iboats
jerryjerry05
Some of the helldrives used a different impeller.F523065-1 Should be the one.
Some parts guys will give you a Merc.impeller.Looks the same just bigger and taller.
DJ87
hey guys, thanks for the help. the model number i have is 1251x7b and right below that it says hp 125 with my max rpm info.
DJ87
125 through 1989
hey roscoe i see the impeller that you found. that must be it, whats the difference between l drive and plain old 125? is it the lenght of bottom end?
roscoe
Your model number 1251x7b indicates 1987
L-drive is not an outboard.
It is an outboard powerhead, mounted inside the boat extending thru the bottom of the hull, then connected to something that looks like an outdrive.
L-drive , click to enlarge.
DJ87
very different, thanks for the help. i hope to be on the water next weekend!
