justa150merc
- Jun 24, 2014
- 24
Hey guys,
I just recently picked up a 1996 Javelin 369FS with a 115 Johnson fast strike (a factory hopped up 60 degree looper). Max RPM for the fast strike is 5000-6000. I want 5800 unloaded and around 52-5400 loaded. The boat is a 17ft fiberglass hull and has a max HP rating of 130 so this isnt an issue of being underpowered.
The prop is a 3 blade stilletto stainless. I noticed that there is no pitch and diameter stamped on the prop itself but pulled some numbers off of the prop hub. #30319 is what numbers I got along with a few others i didnt write down. I did some quick research and the prop seems to be the advantage II which is a 14.25 diameter and 19 pitch that is recommended for V6s 150 HP and above. The previous owner had the local dealer talk him into a prop that had been sitting on clearance for a while and told him it would work well for the boat.
Would this potentially be my issue? Maybe the prop is too aggressive for a 115? I am also wondering if props are interchangeable for the v4 and v6 gearcases on the OMC's? Seems odd to me as I am a mercury man and that is usually not the case with their props.
The #30319 prop is here:
http://boatpropellers.iboats.com/Sti...pellers/30319/
The motor is in good health and runs well from idle up to 5500 RPM roughly with around 550 lbs in the boat, however the prop blows out on anything more than roughly 1/3 trim and if I go into a turn with the trim up even a 1/4 it will also blow out. Also, while running at around 30 and I punch it, it feels strong up to 40 or so, then once I begin to trim up more, it feels like the prop lost all of its bite and its struggling to hit 43-45 mph at 5500 rpm.
I know this boat is good for a solid 50 mph as my neighbor previously owned the boat and with the stock aluminum it hit 49.6. I havent verified with GPS but there is no way I am hitting that speed now.
Also, holeshot is poor to say the least and has terrible bow lift, it seems non existent.. Any incite fellas? Its extremely frustrating having a prop that is constantly blowing out and has a holeshot that is slower than my 12 foot boat with a 9.8 merc on it.
Thanks in advance!
Thanks in advance!
