Wrong prop or bad tachometer....4.3 Mercruiser AlphaOne
Eduardbro
Hi guys
I have 1991 Larson All American 170 with 4.3 Mercruiser AlphaOne 190HP
I have 14.5 x 19pitch prop. When running WOT test, I max out at about 42mph and tachometer is showing 6000 rpm but it should be between 4400 and 48000.
At first I was thinking I might need to try a different size prop pitch but we are thinking my tachometer might be out of whack, the arrow goes up and down when idle (the engine is running solid good). Also, when just starting to take off the RPM looks to high to be true, between 1000 and 3000.
What is the best/cheapest way to check to make sure my tachometer is working fine...i read that there are some portable/handheld tachometers, are those any good? Any recommendations?
Ayuh,.... Welcome Aboard,.... My timing light has a built in shop tach,....
Texasmark
I'd say your tach is off. If that engine were running that RPM, with no "performance upgrades" it wouldn't be running very long!s (opinion)
QBhoy
Not a chance you’re doing those rpms. Be great to get the rpm verified before going any further
