natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
MCM 165 engine.
Spent yesterday afternoon and half of today installing my alternator conversion kit in the blazing 95 degree Florida sun. Got 'er up and running, measuring a cool 14.5 volts across the battery terminals like the instructions said I should. Got the dashboard voltmeter working (a tiny magnet had slipped off its little shaft). Got the speedometer registering (vertigris in the brass nipple).
Stuck the boat in Santa Rosa Sound, with the same battery that had started the boat several times this morning AND a brand new battery that charged for a good 8 hours, measuring something like 13.5 volts.
The boat fired right up, ran like a top, and showed 15 volts on the dashboard voltmeter. We motored for a good hour before anchoring and swimming in the sound some.
Went to start the engine...rrrr, rrrrr nothing. Oh crap! Switched to the backup battery (that I thought was fully charged). Rrrr, rrrr.....dead too.
Borrowed a battery from a pontoon boater (24 cell, not a 27 cell). Rrrr, rrr, nothing. Both my dead batteries started his 60 hp outboard no problem.
Well, it's 10:45 p.m. as I type this. The pontoon boater towed me in. Took about an hour and a half. While under tow, I rigged both batteries in parallel using a couple of aluminum poles and my flip-flops as insulators. We came so close to starting the engine a couple of times, but the wife didn't let the engine turn over long enough. So close, but so far!
With the help of a complete stranger and my sister, we got the boat home safely. For some reason, I decided to see if I could flush the engine, and on a whim I tried to start the engine. Rrr--VAROOM! It started in about half a turn!!! And this was AFTER I used up some juice lowering the stern drive. This is typical of my life!!!
Is it possible that I didn't charge these two deep cycle 27 cell batteries long enough and there is nothing wrong with my charging system?
I'm perflexed.
I'm perflexed.
