XDP Conversion to OceanX
mckaras
I'm looking for an Ocean X Transom Shield assembly with the inner plate along with a 1.95 Ocean X Outdrive. Can anyone point me in the right direction as far as where there may be used ones for sale?
I do have an Ocean X outdrive however it is the 2.14 ratio and I need the 1.95 for a 5.7 GxOsi. I have a few options as far as getting a 1.95 ratio out of the existing drive I have... Either by changing the upper gear set or by changing out the complete upper unit. Otherwise I also have the option of buying a 1.95 gear ratio Ocean X Drive.
This boat will be freshwater as well, perhaps a switch over to a regular DPS-A drive is advised over the Ocean X however most for sale have converted to an Ocean X. Any and all insight will help!
If there are places that dealer demo engines and transom/outdrive packages are sold or auctioned off at that would be greatly appreciated!
Senior B
With that difference, you could compensate by going up a prop size from say F4 to F5 if the drive you seek doesn't come along.
mckaras
Likely what I will do is change the gear set to a 1.95 ratio. I will keep the standard prop size that is coming on the Ocean X outdrive I have coming in.
mckaras
I see what you are saying, that I can keep the 2.14 ratio drive and not modify it to a 1.95 and upgrade prop size from F4 to an F5?
It will likely run as much as the gear change as they run $1300 online for a new gear set plus install. New Props will be in about the same price range.
Now if I do change the gear ratio to a 1.95 do I need to change the props or can I keep the same ones? I have a spare set of FH5 props.
Senior B
I would see where the RPMs are at full throttle. A good match would be 5200 RPM with a light load and @ 1/2 a tank of fuel.
