Y- Pipe Question
Williamsra
What is the purpose of the two smaller ports on the pipe? The bigger port is exhaust to the prop, the smaller ones are exhausting through the transom assembly. Never noticed till running on muffs.
jimmbo
Someone might have put one of those Annoy Everyone Else on the Lake, thru hull Noise making kits.
Pictures would help a lot
Ayuh,..... Those are the idle relief ports,....
the idle relief ports are needed to reduce the back pressure enough so the boat continues to run at idle.
