Bt Doctur
- Aug 29, 2004
- 19,413
yahama 150, need a bit of guidence
Motor is 150TXRM 6G4 UL 756892
Took on a job to replace the shift rod and I think i have all the bolts,nuts removed except for 2 long ones. the rearmost one on the port side and the middle one on the stbd side.The other 4 came out with moderate pressure but no corrosion on the shank of the bolt, just the threaded area.
Are there any tricks I can use to remove the 2 remaining ones and can I get a scan of the manual showing the power head removed from the lower section.
If talking is easier pm me for my cell.
Has been suggested to drill thru the housing and bolts ,then remove remaining bolt from the powerhead?
Thanks
Thanks
