Yahama F40 idles rough and dies with throttle
JGator
2000 F40. Ran fine a month ago, not now. New fuel and cleaned with sea foam spray. When we lifted the Prime Starter assembly up in its socket just a bit and all ran well, both idle and open throttle. The parts stem does not change positions regardless of the ignition switch position. Is this normal? How does this part function normally?
BTW it was warm, as I've read it should be in another thread http://forums.iboats.com/showthread.php?t=547480&highlight=PRIME+STARTER+ASSY.
TIA
Jim
99yam40
Re: Yahama F40 idles rough and dies with throttle
Prime start is for starting and the initial warm up. as motor runs power from charging system heats it up and closes off the extra fuel.
Sounds like you need to have the carbs cleaned properly and then readjusted using proper equipment,.
spraying stuff at carbs does not clean the passages and jets and yours are plugged if it will not run
JGator
OK, so can you tell me why lifting the prime start piece 1/8 inch up seems to improve the rough idle and stumble issue when opening up the throttle?
JGator
Also should the stem piece move from its cold start position at some point?
JGator
99, I see you were at one time as curious about this piece of technology, prime start system, as I now am http://forums.iboats.com/showthread.php?t=357552
I have no problem with your suggestion of carb cleaning...just wondering how simply raising the device 1/8 inch made the engine run much better...
Jim
99yam40
Probably lifted the needle out of the seat and let the extra fuel into the motor.
Did you try running in the open position to see if that made a difference?
If you read that thread then you should have a good idea of how it works and what Rodbolt had to say at the end about the F40 needing to idle for a while before running up the RPMs. I am not sure how close the 2 and 4 stroke systems are to each other, but rodbolt did mention the 2 stroke had the diaphragm but he did not say that about the 4
Also Rodbolt has said that the F40 is a hard one to clean and set properly, the passages and jets are small and plug easily.
JGator
Thanks for the information, it's truly appreciated, but not sure what you mean by running in open position. Throttle? Or the prime start piece?
Jim
99yam40
prime start emergency switch
JGator
I'm trying to locate this emergency switch, would you happen know where I should be looking?
Jim
99yam40
Not sure about a F40, but on my C40 it is on the front of the prime start mechanism. It has a normal,open, and closed setting
your owners or service manual should give you that info if it has one
JGator
I've allowed the prime start piece get cold, 50?~ and measured the stem then ran engine on idle for 5 minutes then measured the stem it was 1/8 inch longer. So it appears to be working as designed.
handle
I have the F40 06 yamaha with poor low speed and idle running conditions. Don't know enough about the prime start device but will tell you that the pilot jets on my motor are so small that they clog easily. On my particular carbs the F30 has larger pilot jets than the F40. Maybe it's time to increase the size. Nobody seems to want to address this matter.
JGator
I'm wondering if it wise to run the carbs dry if the boat won't be back in the water every few weeks.
Jim
JGator
Got the boat back from my newest best marine mechanic friend! System had much debris in fuel likes and carbs, one bowl needed replacing do to corrosion. Took the boat out today and it started in less than 2 seconds, ran great in all RPM ranges.
Carbs were rebuilt, fuel hoses replaced, pump cleaned and internal filter/strainer replaced.
