1995 Yamaha 150
The symptoms...
I've been the owner for 7 years with no problems. Always routine maintenance.
Worked great last year.
First out this year and would not go into fwd. Just grrrrrrrrind
I disconnected the shift cable and while slowly turning the prop I can easily slide the linkage into fwd but if I apply a little turning force to the prop (while holding the linkage in fwd), it sounds/feels like it's jumping out of gear.
Reverse works fine, however I have to move the lever a bit past neutral to get completely out of rev gear.
I drained the gear oil and it was clean but had a slight milky texture. I use the red gear oil and it was pink. No doubt water.
Any insight would be greatly appreciated.
The symptoms...
