formula233
- Apr 20, 2006
- 3
Hello I have a 2000 yamaha c115,non injected,engine mounted on a older 17 aquasport center console,21 pitch prop.It will turn 5300 - 5500 rpm. depending on weight.The engine runs great while planed off.Even when you first leave the ramp idling 15 minutes,with clean plugs,no problem.The first time you plane off, perfect,the problem starts when you decelerate back to trolling speed or idle.It sounds like its running off 2 cylinders or so.After that, it will not ever idle right again.Come home and clean the plugs,idles and runs good.The carbs were just done and fuel pump replaced.So when the plugs are clean it runs,ignition must be ok or not? First time, I took off one wire at a time,and the port top and bottom cylinder were the ones foul.All look rather wet.Would it mean both carbs would have to be bad in order for all plugs to be wet.Idle screws are set at 1 turn out.Engine is new to me,I don't suppose a decarb would fix this,probably wouldn't hurt though or am i wrong?Thanks 233
