maineiac5586
- Feb 14, 2009
- 771
Just fired up new to me 2001 yamaha 130 hp 2 stroke. Rebuilt the carbs, new fuel pump, new spark plugs. I started it on the muffs at my house. Idle is low 5 to 600 rpm. I left the 4 idle mixture screws at current setting when I redid the carbs. I checked the roller cam pickup point is in spec. I turned the idle speed adjusting screw 1 whole turn clockwise and it only raised rpm about 50 rpm. I don't want to go too far as I don't want the carbs to be on the next circuit. Hope that makes sense. Should I set all mixture screws to 7/8 open as per manual? Thanks
