Yamaha 130 hp Water Pump Impeller Replacement Question 1988 two stroke
fishon71
When I pulled the housing from my water pump to replace the impeller I had to remove this stainless ring with a plastic insert before I could remove the impeller off the drive shaft. I mangled the stainless/plastic piece as it would not come off easy. There also where some shims under the stainless/plastic ring and do not see any of these items listed in the water pump or lower unit break down of parts. Where do these parts show in the break down or are they suppose to be part of the plastic housing?
erniefish
Re: Yamaha 130 hp Water Pump Impeller Replacement Question 1988 two stroke
i just got done a pair of 225's , it is listed as a shim i think, on my motors i messed up the plastic ring, it was cheap to replace
fishon71
I know its probably cheap but I can't find the part numbers or a picture of these items in the parts break down.
99yam40
Post your model #
Is that lower unit the original on the motor?
Maybe it is from a different year
fishon71
Post your model #
Model number is 130ETXG 1988 I looked at several other years and I do not see this part listed either
99yam40
look at a 1993 to see if that looks like what you are talking about
fishon71
I think someone hit the nail on the head - it is a newer lower unit and the older did not have these parts - thanks
