Yamaha 130hp 2 stroke Trim/Tilt problem
Caper44
Hi,
I bought an old boat I am fixing up and am having problems with the trim/tilt. It will go down fine but it will not go up. When I press UP in the switch I just get a clicking sound. The motor is ok, I can disconnect the power to it run 12v straight to it, then reverse them and it will go up and down. When I press the UP switch it gives power to both sides of the motor. Does this sound like a bad relay.....or possibly in the switch.
Thanks
sam am I
Relay.........Swap the relays and see if the problem follows the suspect bad up relay to now the down.
