Yamaha 15 hp no spark
geo7
I have a 2001 f15EHZ. It started but would not run with choke off. I pulled plugs and 1 plug was fouled. I cleaned both plugs and reinstalled. Now I have no spark to either plug. I removed plugs and grounded them against the block turned motor over and no spark to either plug. Is this the right way to check???
James R
Re: Yamaha 15 hp no spark
Has this motor been used in salt water? If it has then the plug wire connections could be corroded. Take a look.
geo7
No, All wires are clean with no corrosion.
