Yamaha 150 hp 4 stroke water pump change- Question
sullmate
I have a 2016 engine. I will be doing my first water pump change. This engine has a 25 inch shaft. There is a spacer used to change this engine to 25 inch. from 20 inch. shaft. Done by Yamaha at factory. There are 2 sets of bolts on each side of the lower unit. Which set of side bolts should I remove. The upper 3 or the lower 3 bolts?? I know about the trim tab bolt removal and the bolt hidden under the trim tab housing. Please advise. Thanks, Sullmate
99yam40
just from thinking a little bit, I would remove the lower bolts , other wise you would have the extension on the housing in the way to remove the water pump.
But then it is never a bad idea to remove and lub all of the bolts to keep them from locking up
