Yamaha 150 txrc cranking problems
devildg4671
I have a 2005 Sea Pro 206cc with a yamaha 150 txrc. It cranks and run greats in the beginning. But after being anchored up for an hour or so i have a very hard time getting it to start. I usually have to prime it a few times and choke it. Which helps but usually before I get the anchor back up it shuts off. Any ideas
erniefish
Re: Yamaha 150 txrc cranking problems
i have that motor as well, i do not have that problem, have you ever cleaned the carbs? new plugs?
Bob Gilvary
I'm just down the road from you towards Shallotte. Supply actually. If you want to bring it by.
devildg4671
Thanks everyone, I changed the plugs shortly after noticing the problem. I have yet to clean the carb. Is it simple ?
