I recently rebuilt the powerhead on my 1988 yamaha 150 . At around 1800 RPM it starts missing bad and will not rev past 2100 RPM . I did a compression test and had between 145 and 150 psi on all cylinders . On the water if you shut the boat down and let water drain from block then restart it the motor will rev up to about 4500 RPM and then quickly fall off back around 2000 RPM . It is getting plenty of fuel . Can someone please help me diagnose the problem before I pull What little hair I have left out ?
