moonlightin
- Jun 17, 2009
- 2
Having idle problems and top end power problems. boat just won't idle consistently. no power over 3500 RPMs
here is what i have had done.
1. Compression test
2. replaced oil float level switch
3. replaced 3 new fuel lift pumps
4. replaced VST fuel filter
5. checked high pressure fuel pump 38psi
6. checked fuel pressure relief on vst
7. ran engine on shop tank with good fuel supply
8. swapped out ECM
9. scaned engine for touble codes NONE
10. performed injector resistance test
11. checked pulser coils
12. checked engine timing
13. swapped out high pressure fuel pump
14. checked 02 sensor
15. cleaned all engine grounds and checked all connectors
16. tried running engine with shift/ throttle cables disconnected
17. checked main engine relay
18. changed boat batteries
19. syncronized throttle bodies
20. adjusted TPS voltage sensor
21. checked for vacuum leak on fuel line
22. CAN GET ENGINE TO IDLE WITH YELLOW LEADS DISCONNECTED AT ECM UNIT
(no wire diagram for computer)
ENGINE SNEEZES AND SPITS WHEN LEADS ARE CONNECTED
NO VOLTAGE LOSS AT FUEL PUMP WITH LEADS DISCONNECTED
ENGINE WILL ALSO RUN WITH KNOCK SENSOR DISCONNECTED
23. checked all ignition coils
24. checked for spark on all cylinders
25. install new spark plugs
26. check stator output
27. checked for propeller slippage
BAYTESTED BOAT WITH HIGH END POWER LOSS (EXTREME)
HELP!!!
1. Compression test
8. swapped out ECM
HELP!!!
