Gambler2101
- Nov 26, 2008
- 11
I have a 2001 hpdi z150 that I probably need to replace the block on its part number is 68H-15100-00-1S . Can I use a 68F-15100-00-1S z200 block instead? Not sure if there is a difference in port timing or anything that I need to be aware of before sending this 200 block to the machine shop. They look identical but the different part numbers are throwing me. I hate to spend a lot of time and money to find out that there was a difference that made them incompatible. They are both 2.6's and the ports look the same but I have no way of measuring the ports exactly nor do I know if larger ports would cause issues anyway since the injectors and ecu control the amount of fuel getting sent into the combustion chamber. Anyone face this before and come up with a definitive answer? Thanks
