Re: Yamaha 200 OX66 not shutting down clean
your idle speed is a bit high, try a careful link and sync to insure the throttle shutters are full closing and the oil pump link rod is adjusted correctly as well as the TPS voltage is correct.
the VX indicates its a Vmax OX66 it also tells me by the Y designation its a 2000 model which would be a 3.1L engine.
Vmax OX66 motors did NOT use CCS so they are very touchy on linkage adjustments.
also carefully check all ECU grounds and the ground lead going to the keyswitch.
when switched to off the 12V for the fuel pump and injectors and ECU is removed and the ign system taken to ground.
have you tested the lift pump diaphrams for leakage or the injector rail pressure for a possible leaking injector?
spec for idle speed is 730 plus or minus 30 RPM, typically we see closer to 650 RPM so 850 is a tad high.
