seatrout13
- Aug 1, 2007
- 1
Can anyone give me some good advice on this problem? I have a 2001 Yamaha 150HP and the Tilt cylinder is leaking. My Tilt/Trim unit has 3 shafts, I believe the two outer shafts are for the Trim function and the center shaft is for Tilt function. Oil is leaking around the center shaft! I did recently replace the fluid (Tilt/Trim fluid they sell at Walmart). Did I use too much fluid or the wrong type, I'm not sure. We were on vacation and I was in a pinch. I raised the engine about half way, connected the fluid bottle to the fluid inlet and raised the engine all the way to the top - the fluid was sucked from the tube into the reservoir. Any ideas as to what my problem is would be much appreciated.
Thanks
Thanks
