Oil alarm was going off, plenty of oil in external tank, internal reservior was below minimum line. used manual pump switch to raise above line, engine then ran with alarm for a minute and then alarm went off. All seemed to be well, then oil reservior continued to fill to the top, well above high oil line and engine started smoking terribly.....tried to burn it off but no luck. Plugs then fowled....need some help from here? thanks!
